Replacing a broken or scratched lens on a Polaroid Sun 600 LMS.
Move film door slide on the left side of camera forward.
Pull film door open.
Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
Use a spudger on each side to separate the flash segment from the main body.
Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
Place left hand on the gray section and right hand on the black section.
Pull the sections apart.
Carefully remove the damaged lens from the interior of the camera.
Replace with a new lens.
How could I clean the viewfinder? I have a little bit of dust stuck behind the lens
