Polaroid S10 Battery Replacement
  1. Polaroid S10 Battery Replacement, Removing the backcover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid S10 Battery Replacement, Removing the backcover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid S10 Battery Replacement, Removing the backcover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid S10 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid S10 Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid S10 Battery Replacement, Battery Connection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Follow these instructions to reassemble your device.
James
crwdns2935283:003/16/15crwdne2935283:0
367 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 1-4, May Spring 2015 crwdns2935289:0Colorado Springs, Team 1-4, May Spring 2015crwdne2935289:0
UCCS-MAY-S15S1G4
crwdns2935297:013crwdne2935297:0
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,367
