The motherboard contains most of the electrical components of the device. It is a delicate piece of hardware but can easily be removed.
Pry the seam between the screen and the case and slide it on all four sides with a large plastic opening tool until the plastic case comes off.
Lift the device off of the case and flip over the device so that it sits screen side down.
The device is now free from the plastic case.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Wedge a plastic card beneath the battery unit and wiggle the card side to side and up and down gently until the glue sealing the battery to the device is broken.
Peel back any yellow tape not directly attached to the battery.
Using a soldering iron, desolder the two wires that connect the battery to the motherboard.
Remove the two 5mm screws attached to the top right and bottom left corners of the speaker
Solder off the wires connecting the speaker to the device
Pull the speaker out of the casing to release it.
Using the ph#00 screwdriver, remove the four 5mm screws connecting the motherboard to the casing.
Using a spudger or a fingernail, detach the two ribbons from the motherboard by pushing the plastic tab away from the Zero Insertion Force connectors.
Now carefully remove the motherboard.
