The shutter switch is the button which is to be pressed when the user wants to capture an image. If for some reason this switch needs to be replaced, this guide will be showing how to remove the shutter switch.
Begin by opening the top of the camera (flash assembly) to a slight angle.
Next, angle the flash assembly slightly upward and pry off the connections carefully.
Slide the action button, on the bottom of the camera, to open the bottom.
Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
Pull off the face plate.
After the face plate is off, the shutter switch should slide out easily.
where did you get the replacement parts for this?
Jacob Sokolove - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’d love to find a new shutter piece..
Joni Korkkula - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
