Polaroid OneStep 2 Lens Replacement
  1. Polaroid OneStep 2 Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement, Lens: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four Phillips #0 5 mm screws on the base of the camera.
    • Remove the two pieces of the base.
  2. Polaroid OneStep 2 Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four Phillips #0 5mm screws on the top of the inside base piece.
    • Remove the Phillips #0 5mm two screws on the bottom of the inside base piece nearer the strap.
    not correct. what about the electrical connections?
    Tekin - crwdns2934203:0crwdne2934203:0
    also you do not need to unscrew the back mirror unit. if you take it off you can not put it back and it is not necessary. I learned the hard way, I can not put it back.
  3. Polaroid OneStep 2 Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black inside base piece.
    BE CAREFUL! This is missing the part where there are two ribbon cables that connect to the upper body of the camera. If you take the back board off without disconnecting the one closest to the front and side of the camera you are likely to break them.
    primate.uprising - crwdns2934203:0crwdne2934203:0
  4. Polaroid OneStep 2 Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With force separate the white front piece from the back of the camera. You will use your hands and pull it apart.
    The white front isn't coming off. What do i do?
    Lia Biasi - crwdns2934203:0crwdne2934203:0
  5. Polaroid OneStep 2 Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two Phillips #0 3mm screws on the black ring holding the lens in place and remove the ring.
  6. Polaroid OneStep 2 Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid OneStep 2 Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear plastic lens with tweezers.
Abby Boucher
crwdns2935283:009/10/18crwdne2935283:0
823 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S1-G1, Bedsole Fall 2018 crwdns2935289:0University of Alabama, Team S1-G1, Bedsole Fall 2018crwdne2935289:0
UA-BEDSOLE-F18S1G1
I followed this guide to a T, but it stops right before the replacement. I can even see the cracked lense in the last photo beneath the plastic lense you removed. How would one remove that internal lense and replace it?
JAD - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 7,996
