Polaroid LCD-0700P Metal Holding Bars Replacement
  1. Polaroid LCD-0700P Metal Holding Bars Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid LCD-0700P Metal Holding Bars Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the entire device over, so that the underside of the device is facing upward.
    • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
  2. Polaroid LCD-0700P Metal Holding Bars Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid LCD-0700P Metal Holding Bars Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
    • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Be careful when separating the front and back covers, as the two are held together by a thin wire.
    • Separate the halves of the case.
  3. Polaroid LCD-0700P Metal Holding Bars Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
  4. Polaroid LCD-0700P Metal Holding Bars Replacement, Metal Holding Bars: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Philips #0 screwdriver to remove the screws for the bar you are replacing.
  5. Polaroid LCD-0700P Metal Holding Bars Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the bar.
Kevin
crwdns2935283:001/20/12crwdne2935283:0
22 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 8-14, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 8-14, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S8G14
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 835
