Polaroid I-2 Film Shield Replacement
  1. Polaroid I-2 Film Shield Replacement, Safety information: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Safety information: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Safety information: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have any film left, take some photos and remove the cartridge! Disassembly will expose the film and damage it.
    • Before you begin:
    • Power down and unplug your camera.
    • Put on the lens cap to avoid scratching your lens during disassembly.
  2. Polaroid I-2 Film Shield Replacement, Open the film door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Open the film door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps, "left" and "right" are written from the perspective of using the camera—or when the lens is facing away from you.
    • Use the latch on the left side of the camera to open the film door.
  3. Polaroid I-2 Film Shield Replacement, Insert a blocker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Insert a blocker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Insert a blocker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fold a piece of cloth or napkin (or the included bag) into a small square.
    • Insert the cloth into the film compartment far enough to block the film door from closing during disassembly.
  4. Polaroid I-2 Film Shield Replacement, Flip the camera over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Flip the camera over: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Flip the camera over: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the camera over, making sure the cloth stays lodged in the film compartment.
  5. Polaroid I-2 Film Shield Replacement, Unfasten the bottom cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws securing the bottom cover.
  6. Polaroid I-2 Film Shield Replacement, Unclip the bottom cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Unclip the bottom cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Unclip the bottom cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick under the top left corner of the bottom cover, near the slider button.
    • Tilt the pick up and push to position the pick between the bottom and front covers.
  7. Polaroid I-2 Film Shield Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick toward the rear of the camera to release the clips along the left edge.
    • Leave the opening pick at the bottom left corner to prevent the clips from resecuring.
  8. Polaroid I-2 Film Shield Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of a second opening pick under the top right corner of the bottom cover.
  9. Polaroid I-2 Film Shield Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick toward the rear of the camera to release the clips along the right edge.
  10. Polaroid I-2 Film Shield Replacement, Remove the bottom cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the bottom cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the bottom cover: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, the bottom cover clips should be released. If not, slide an opening pick along the perimeter of the back cover to release any remaining clips.
    • Tilt the back of the bottom cover upward and pull it away from the camera, making sure to thread the film door lever from its recess.
    • Remove the back cover.
    • During reassembly, insert the film door lever into its recess before aligning the bottom cover and pressing it into place to secure its clips.
  11. Polaroid I-2 Film Shield Replacement, Disconnect the film door: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Disconnect the film door: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Disconnect the film door: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the film door's left hinge and the frame.
    • Twist the spudger to separate the rubber hinge grommet from its peg in the frame.
    • Pull the film door towards the front of the camera to completely disconnect its left hinge.
  12. Polaroid I-2 Film Shield Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the left edge of the film door up to separate the left hinge's rubber grommet.
    • Remove the film door.
    • At this point, you can remove the cloth blocker from under the print roller.
    • During reassembly, hook the left hinge on its post and push the right hinge over its post until it snaps into place.
  13. Polaroid I-2 Film Shield Replacement, Unfasten the print roller: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Unfasten the print roller: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the 3.9 mm-long screw securing the print roller.
    • The screw is hidden and might require a flashlight to see properly.
  14. Polaroid I-2 Film Shield Replacement, Disconnect the print roller: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Disconnect the print roller: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Disconnect the print roller: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two plastic tabs that secure the print roller.
    • Use the tip of a spudger to depress both the plastic tabs until their hooks release from the print roller.
    • You'll hear an audible "click."
  15. Polaroid I-2 Film Shield Replacement, Remove the print roller: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the print roller: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the print roller: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the print roller by one of its arms and pull it straight out of its plastic housing.
    • Pull straight away from the housing to avoid bending or warping the metal.
    • If you're having trouble, make sure the clips are released. You may have to hold the clips down while pulling.
  16. Polaroid I-2 Film Shield Replacement, Reassembly information: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Reassembly information: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Reassembly information: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The print roller is a sensitive component. Be extremely careful during reassembly to not bend or warp the metal.
    • During reassembly, note the following to properly reinsert the print roller into its plastic housing:
    • There are two metal L-shaped rails at the bottom of the print roller that have to slide under cutouts in the plastic housing.
    • There are two metal hooks at the top of the print roller that have to fit under the top corners of the plastic housing.
    • Insert the print roller at a downward angle to fit the hooks in first before sliding the rails into place.
    • Push the print roller into its plastic housing until you hear the plastic tabs click back into place.
  17. Polaroid I-2 Film Shield Replacement, Insert an opening pick: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Insert an opening pick: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Insert an opening pick: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick straight down into the gap between the bottom right corner of the film shield tray and the plastic housing.
    • Push the pick downward and pry upward to get the pick between the film shield tray and the plastic housing.
  18. Polaroid I-2 Film Shield Replacement, Unclip the film shield tray: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Unclip the film shield tray: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Unclip the film shield tray: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two clips securing the film shield tray.
    • Slide the pick toward the left edge of the plastic housing to release the two clips.
    • You'll hear an audible "click" and feel the tray release from the plastic housing.
    • During reassembly, push the film shield tray into place until you hear the clips click into place.
  19. Polaroid I-2 Film Shield Replacement, Remove the film shield tray: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the film shield tray: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the film shield tray: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the film shield tray out of its recess and remove it.
  20. Polaroid I-2 Film Shield Replacement, Remove the film shield: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the film shield: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement, Remove the film shield: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The film shield sits on four alignment pegs.
    • Use tweezers to pull the film shield off its alignment pegs.
    • During reassembly, use tweezers to align the film shield over its pegs and a use spudger to press it into place.
  21. Polaroid I-2 Film Shield Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid I-2 Film Shield Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the film shield out of its slot in the plastic housing and remove it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Polaroid I-2 Answers community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169.220 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.530crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 725
