Polaroid Cube Lens Replacement
  1. Polaroid Cube Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Lens Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the battery pin connector from the circuit board.
  11. Polaroid Cube Lens Replacement, Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Lens Replacement, Lens: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a J00 screwdriver to unscrew the two circled 3.5mm Phillips-head screws from the circuit board.
  12. Polaroid Cube Lens Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Lens Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a J00 head screwdriver to unscrew the two 3.5mm screws from the circuit board.
  13. Polaroid Cube Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the lens from the unscrewed circuit board and replace the broken lens.
    Hey! Where can I buy a lens for the Polaroid Cube?
    Karlie E - crwdns2934203:0crwdne2934203:0
Grant Baldwin
crwdns2935283:009/29/16crwdne2935283:0
685 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-2, Harley Fall 2016 crwdns2935289:0IUPUI, Team 3-2, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S3G2
Where can I find a replacement lens for the cube+? I broke the bubble part of the lens
Ben McAlister - crwdns2934203:0crwdne2934203:0
Maybe is posable replace wider view angle lens ? original looks like fpv camera lens foxeer or runcam micro. Possibly Caddx micro cam lens
starsas777 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 2,399
