This guide will walk you through the steps of replacing the battery on your Polaroid Cube. Make sure the device is completely powered off before disassembly, and that you have all of the required tools.
Remove the SD card cover by twisting it using a Plastic Opening Tool
Use the Plastic Opening tool to pry off and remove the front cover.
Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
Use the Plastic Opening Tool to pry open the shell of the camera.
There are four latches, one at each corner, that you will need to detach.
Remove shell from top and bottom of camera.
Remove the rubber seal wrapped around the camera.
Remove the tape wrapped around the battery.
Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
Use the plastic opening tool to remove the circuit board that the battery is connected to.
Gently remove the battery pin connector from the circuit board.
crwdns2935229:010crwdne2935229:0
crwdns2947412:013crwdne2947412:0
Any idea where to find the replacement batteries?
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
Was anyone able to to find the replacement batteries for the Cube?
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Podrías mandar enlace de compra? Link gracias marin_zgz_@hotmail.com .batería Polaroid cube
Any advice on where to buy the battery?
oldturkey03 was kind enough to give us the name of this small battery: Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V. His detailed answer is right about Polaroid cube battery type. Anyone knows it?
However, I tried to find a place to buy it from and no one seems to sell it. At least, no one ebay and not even on aliexpress.
Podrías mandar enlace de compra el link de las baterías de la polaroid cube . Marin_zgz_@ hotmail.com
please send me that link too exahead@gmail.com
Is this advice for Polaroid Cube+edition?
i need batter money how mach
I can only find 3.7v versions available, and after watching a repair video using similar replacements, they appear to work!
