Polaroid Cube Battery Replacement
  1. Polaroid Cube Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SD card cover by twisting it using a Plastic Opening Tool
  2. Polaroid Cube Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Plastic Opening tool to pry off and remove the front cover.
  3. Polaroid Cube Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a J00 head screwdriver, remove the four 3.27mm screws from the front of the camera near the lens.
  4. Polaroid Cube Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Plastic Opening Tool to pry open the shell of the camera.
    • There are four latches, one at each corner, that you will need to detach.
  5. Polaroid Cube Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove shell from top and bottom of camera.
  6. Polaroid Cube Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber seal wrapped around the camera.
  7. Polaroid Cube Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the tape wrapped around the battery.
  8. Polaroid Cube Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Cube Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Cube Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a J00 head screwdriver, unscrew the four 3.46mm screws from the top and bottom circuit board.
  9. Polaroid Cube Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Cube Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to remove the circuit board that the battery is connected to.
  10. Polaroid Cube Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the battery pin connector from the circuit board.
crwdns2935229:010crwdne2935229:0
heath lamkin
crwdns2935283:009/29/16crwdne2935283:0
372 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-2, Harley Fall 2016 crwdns2935289:0IUPUI, Team 3-2, Harley Fall 2016crwdne2935289:0
IUPUI-HARLEY-F16S3G2
crwdns2947412:013crwdne2947412:0
Any idea where to find the replacement batteries?
hooverhogg - crwdns2934203:0crwdne2934203:0
Well described! Need to buy a replacement battery though but I have no idea about the specs of the battery. Any information?
seyhangul - crwdns2934203:0crwdne2934203:0
Fuji 402424 Lithium ion (Pouch)battery 240mA 4.8V Can’t find it. Can anyone help with a source?
David F O'Connor -
Was anyone able to to find the replacement batteries for the Cube?
yzorger - crwdns2934203:0crwdne2934203:0
the cube requires a two-pack battery which has a single plug for both of them and so they have to be wired together in just the right way to be able to fit inside the cube. i guess it's not possible to buy replacement batt. and paying minimum $16 for it? u could just buy a new one for too close to $16. or a used one.
Timothy Davenport - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 10,080
