Polaroid Automatic 100 Bellows Replacement
  1. Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement, Bellows: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fully extend the bellows by lifting the #1 lever.
    • Remove the camera cover in order to make the camera easier to work with.
    • When collapsing bellows, press down on the metal frame above the bellows.
  2. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the two battery cable tabs off of the bellows.
  3. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
    • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
    • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
  4. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the back cover by pushing the lever on the bottom towards the left.
  5. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
    • To make the screws easily accessible, close the bellows by pushing on the metal frame.
    • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
  6. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
  7. Polaroid Automatic 100 Bellows Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polaroid Automatic 100 Bellows Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bellow tabs back with long needle nose pliers.
    • Remove the bellows.
Katie Miller
crwdns2935283:004/14/15crwdne2935283:0
680 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-3, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-3, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G3
crwdns2942667:0crwdne2942667:0 2,288
