Polar V800 Display Replacement
  1. Polar V800 Display Replacement, Waterproofing Seal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar V800 Display Replacement, Waterproofing Seal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In this guide, the wrist band of the Polar V800 is removed for a clear view of the back panel. If you find it helpful, you may want to remove the wrist strap. Please reference the Watch Band Replacement guide for removal instructions if you wish to do so.
    • Ensure your Polar V800 sports watch is powered off before continuing.
    • Remove the eight, 7.4 millimeter-long screws on the back of the watch with a T5 head-type, torque screwdriver.
  2. Polar V800 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently separate the watch housing from the back panel.
    • The watch should come apart easily after removing the screws. If you experience difficulties separating the housing and and back cover, use a spudger to gently pry apart the back panel and the button and screen protector housing.
  3. Polar V800 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The waterproofing seal is the red, elastic band that surrounds the display of the watch.
    • Remove the waterproofing seal.
    • During reassembly, align the red seal in the groove surrounding the glass screen on the main watch housing to ensure a watertight seal.
  4. Polar V800 Display Replacement, Display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar V800 Display Replacement, Display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a T5 torque screwdriver in the upper right and lower left diagonal 4mm screws that hold the white plastic down and rotate the screwdriver to the left, removing the screws.
    I'll like tobuy a new display, but it is impossible for me, do you have the name, or a reference number?
    juan_dinio69 - crwdns2934203:0crwdne2934203:0
    I’ll like to buy a new LCD/ display, but It is for me, do you have the name, or a reference number?
    I’m searching for a replacement display, too.
    Geibrasch Ssriepwutt - crwdns2934203:0crwdne2934203:0
    La pantalla no parece la misma con la referencia que distes???
    WILSON ARAYA -
    Me puedes enviar con seguridad la referecia de la pantalla Lcd para el polar v800.MUCHAS GRACIAS
    DISPLAY # ????????
    wilsoncr_4@hotmail.com
    WILSON ARAYA - crwdns2934203:0crwdne2934203:0
  5. Polar V800 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display from the board from the top side of the watch, revealing the display connectors underneath.
    Cual es la referencia del display???
  6. Polar V800 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polar V800 Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, gently pull the display wiring out of the two connectors that attach the display to the motherboard.
    • If the wiring isn't coming out very easily, try wiggling it as you pull it out.
    The connectors must first be opened by turning the white levers up.
    Mark Paju - crwdns2934203:0crwdne2934203:0
Jarod Lyles
crwdns2935283:004/18/18crwdne2935283:0
833 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G6, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S17-G6, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S17G6
crwdns2947412:015crwdne2947412:0
Please tell me where can I found spare parts for polar v800 ( motherboard,display)
Thank you
Dimitris Karantonis - crwdns2934203:0crwdne2934203:0
Por sin la encontré. Lleva una Sharp LS013B7DH03
ivan.salson -
Please tell me where can I found spare parts for polar v800 ( motherboard,display, also the case and waterproof seal )
Thank you
Alban Cambronero - crwdns2934203:0crwdne2934203:0
I need to bought a lcd for this watch, someone knows where i can buy it ? Best regards
antonio Fernandez - crwdns2934203:0crwdne2934203:0
I need to buy a lcd display, too. Does anyone know where to buy?
Richard Helle - crwdns2934203:0crwdne2934203:0
good morning. could you get the v800 display? do you know where is it possible to get? thank you
SERGIO -
Same question here. Do you guys know if Polar sells spare parts? I just need the top of the casing.
anonymous 3840 - crwdns2934203:0crwdne2934203:0
Por favor, dígame dónde puedo encontrar repuestos para polar v800 (Carcasa, pila…)
Cesáreo RamosTapia - crwdns2934203:0crwdne2934203:0
bonsoir .est ce que vous pouvez me dire ou je peu trouver l’afficheur merci
kenoussi - crwdns2934203:0crwdne2934203:0
where i can buy this lcd display ?thanks….
Where can i buy that screen? Thanks
ramonserrano - crwdns2934203:0crwdne2934203:0
Good tutorial, but it is useless if you cannot get the display replacement.
ivan.salson - crwdns2934203:0crwdne2934203:0
Hello.Thanks for your video. Just let me know where can I find an LCD for my broken V800 Polar.Thanks
Wolf Gangy - crwdns2934203:0crwdne2934203:0
Sharp LS013B7DH03
Este display NO IS CORRECT
crwdns2942667:0crwdne2942667:0 9,204
