Polar M400 Watch micro-USB connector Replacement
  1. Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Polar M400 Watch micro-USB connector Replacement, Disconnecting the flex PCB: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the screen replacement tutorial to dismantle the watch.
    • Carefully lift the screen from the board.
    • Disconnect the USB's flex PCB from the main board. Save the red rubber seal of the USB connector for later.
    • Use a tool like a helping hand to hold the USB connector part.
    • Using a heat gun, blow hot air underneath the PCB.
    • Once the solder is melting give the connector a good tap in order to make the PCB fall loose.
  2. Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch micro-USB connector Replacement, Soldering a new USB connector: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new USB connector on a flat surface with its pins pointing upwards.
    • Place the PCB on top on the pins, the exposed copper traces on the flex PCB facing the flat surface.
    • Using an iron, solder the PCB by heating all the pads at the same time (as much as possible) and apply pressure so that the pins of the USB connector come through.
  3. Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch micro-USB connector Replacement, Sealing the USB connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect the flex PCB back to the main board.
    • Reassemble the watch stopping before screwing the lid back.
    • Add hot glue to the base of the USB connector filling the watch case's cavity. Be careful not to put hot glue inside the connector.
    • While the glue is still hot, put the red rubber seal back on top.
    • Screw the lid back.
    Warning update : In my case hot glue wasn’t so good at waterproofing… The watch steamed up after long activities, which eventually led to corrosion… Maybe silicon would have been better.
    Benjamin Freeman - crwdns2934203:0crwdne2934203:0
    Otra vez,donde se compra el puerto de carga para reemplazarlo?
    Mauricio Siegler - crwdns2934203:0crwdne2934203:0
Benjamin Freeman
crwdns2935283:001/16/20crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Sehr gute Beschreibung,
aber ich finde keine USB-Buchse für die M400 zu kaufen
Wo gibt's die Teile?
martinmartinez644 - crwdns2934203:0crwdne2934203:0
Danke schön. Für den Konnektor allein habe ich auf Aliexpress gekauft : https://www.aliexpress.com/item/32960430...
Benjamin Freeman -
From where do I order usb connector?
Pankaj Singh - crwdns2934203:0crwdne2934203:0
Thanks for posting this guide. Very helpful.
Leon Joubert - crwdns2934203:0crwdne2934203:0
Ich habe die Reparatur noch etwas verfeinert. Die Uhr ist danach auch wieder dicht, der Stecker stabil.
- Die feinen Bohrungen auf der Flex-Leiterplatte bekommt man gut mit Pressluft frei, während man die Pads erhitzt
- Man kann den defekten Stecker von unten soweit freikratzen, dass sich der Metallteil aus der Hülse herausziehen lässt
- wenn man die Hülse etwas ausarbeitet, kann man den neuen Stecker von oben einschieben (nicht kleben für nächste Reparatur ;o))
- Stecker dann einlöten
- Der Ersatz ist wie das Original und sitzt auch ohne Heißkleber fest.
Klaus Neumann - crwdns2934203:0crwdne2934203:0
Hi there
I would like to replace the Polar M400 Watch micro-USB connector.
But I just can’t find it on internet.
Do you know where I can buy it?
Thank you!
Miran - crwdns2934203:0crwdne2934203:0
Hello y'all,
Searching like crazy to find the Polar A370 micro-USB connector. Does any of you have an idea where to find (buy/order) one?
Since Polar can't do this repair anymore, I need to fix my watch by myself and I've been looking all over the internet but I can't find it.
Thank you!
Paul R - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 191
crwdns2942667:0crwdne2942667:0 20,185
