Polar M400 Watch Screen Replacement
  1. Polar M400 Watch Screen Replacement, Wrist Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
    It may be easier to push the pins out in one direction. Unfortunately, I do not recall which direction was easier…
    Nathan Gelderloos - crwdns2934203:0crwdne2934203:0
  2. Polar M400 Watch Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Screen Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
    this shows how to take the battery out; what about replacing it nd securign the ‘electricity leads’ of the new battery to the watch?
    Yonatan G - crwdns2934203:0crwdne2934203:0
    Thanks, very clear straight forward steps
    mohamed elmosalamy - crwdns2934203:0crwdne2934203:0
    même remaque que jonathan
    pas assez de précision sur la remise en place des connecteur de la nouvelle batterie
    François Collet - crwdns2934203:0crwdne2934203:0
    Bonjour François, as tu réussi à remonter la batterie?
    Thierry Grandjean -
    Very strange you haven't completed the procedure.
    John Kirk - crwdns2934203:0crwdne2934203:0
    It says 'To reassemble your device, follow these instructions in reverse order' How difficult is that? So, put battery in, carefully fold contacts back, etc, etc....if that is not obvious, then please do not attempt this at all.
    Mark van der Giezen - crwdns2934203:0crwdne2934203:0
  7. Polar M400 Watch Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the screen from the screen protector using a PH000 screwdriver.
  8. Polar M400 Watch Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Polar M400 Watch Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Attach a new screen to the screen protector.
    • Make sure that the charging port remains accessible, as it can easily become detached during the replacement.
    hello and thanks for the tutorial. I need to fix the screen of a V800 polar and I have a screen of the m400. Do you think I can replace one with the other? Can you confirm what the same LCD is? Thank you very much for everything
    juan_dinio69 - crwdns2934203:0crwdne2934203:0
    Привет, под экраном есть два элемента, нужны их характеристики,позже отправлю фото, какие элементы перегорели.А вообще есть электрическая принципиальная схема polar m400?
    Game Pro - crwdns2934203:0crwdne2934203:0
    Where does even one get a screen in the first place?
    Christos Dimitrakakis - crwdns2934203:0crwdne2934203:0
    Bonjour,
    pouvez-vous me dire ou acheter un port usb pour remplacer sur montre M400 comme expliqué sur le tutoriel?
    Merci
    Denis
    judoclubbastogne - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Nicholas Sanders
crwdns2935283:009/28/17crwdne2935283:0
531 crwdns2915208:0crwdne2915208:0
University of Maine, Team S1-G3, Diaz Fall 2017 crwdns2935289:0University of Maine, Team S1-G3, Diaz Fall 2017crwdne2935289:0
UMAINE-DIAZ-F17S1G3
crwdns2947412:010crwdne2947412:0
Hi, where can i buy the replacement?
Thanks
Mario Sánchez-Barriga Marín - crwdns2934203:0crwdne2934203:0
hi,where can I buy the usb replacement.
GamesFISH_1989 - crwdns2934203:0crwdne2934203:0
Hi, were can i buy the replacement. Thanks
Julien Genon - crwdns2934203:0crwdne2934203:0
https://www.allsystem.cz/
I bought a connector USB there… Maybe can be interesting for someone else…
manuel caudera - crwdns2934203:0crwdne2934203:0
hello manuel,
i tried to order from the web site you specified, but it looks like they are not delivering in france,
cna you please tell me where else i can order this peice
Mathieu Poncet -
Polar won’t sell spare parts so where can I buy a replacement screen or a replacement front case for the M430?
Olivier Grand - crwdns2934203:0crwdne2934203:0
hello olivier,
did u find a resellor for polar spare pieces , i am looking for usb connector fo m400
Mathieu Poncet -
I destroyed the micro usb port on my watch (don’t ask..) I bought another used m400 for a very cheap price, because the screen protector was messed up - full of scratches. I switched the insides of the watches using your instructions. Thank you! I now have a working watch with a clean screen protector and an extra battery just in case I need one later.
Arttu J - crwdns2934203:0crwdne2934203:0
I damaged the star screw (STEP 4). What type is it? Where can I buy these star screws? well thank you
Radoslav Tengy - crwdns2934203:0crwdne2934203:0
Hi
where can i get a polar M400 Screen protector in Cape Town.
Cecil Geduldt - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 9,862
