Pokewalker Button Replacement
crwdns2869540:0crwdne2869540:0: 1.5천
3
17
83
1,480
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
How to Replace a Cracked or Broken Button on a Pokewalker
    1. Pokewalker Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the Screw on the Back of the Pokewalker.
    2. Pokewalker Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Screw with a Phillips #0 Screwdriver
      • The screw is attached to the rear case with washers. don't worry about losing it.
    3. Pokewalker Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the Rear Cover from the Device
    4. Pokewalker Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a Spudger to Remove the Battery
      • Locate the 4 Screws Around the Device
      • Remove all 4 screws with a Y0 Triwing Screwdriver
      • Separate the 2 halves of the Device
      • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
    1. crwdns2935267:0crwdne2935267:0
      • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
      • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
      • Remove the Rubber-button thingy from the upper case
      • I have no idea what that thing is, edit this guide if you do.
      • Remove the 3 Plastic Buttons from the Case
      • It helps that the buttons only go in one way, makes it easier to reassemble
Winni Stuart
crwdns2935283:004/13/14crwdne2935283:0
447 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 83
crwdns2959996:0crwdne2959996:0 1,480
