Pokewalker Button Replacement
  1. Pokewalker Button Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the Screw on the Back of the Pokewalker.
  2. Pokewalker Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Screw with a Phillips #0 Screwdriver
    • The screw is attached to the rear case with washers. don't worry about losing it.
  3. Pokewalker Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Rear Cover from the Device
  4. Pokewalker Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a Spudger to Remove the Battery
    • Locate the 4 Screws Around the Device
    • Remove all 4 screws with a Y0 Triwing Screwdriver
    • Separate the 2 halves of the Device
    • Do not Separate Completely as the Display is Still Connected by a Ribbon Cable
  5. crwdns2935267:0crwdne2935267:0
    • Use a Spudger to Flip the Latch holding the ribbon cable in place and use Tweezers to Pull it out
    • Do not use Excessive force when reinserting the cable, because ribbon cables are fragile
    • Remove the Rubber-button thingy from the upper case
    • I have no idea what that thing is, edit this guide if you do.
    • Remove the 3 Plastic Buttons from the Case
    • It helps that the buttons only go in one way, makes it easier to reassemble
Winni Stuart
crwdns2935283:004/13/14crwdne2935283:0
447 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 750
