Press and Hold on the Top Button
While still holding the top button, press and hold on the small back button.
This button is slightly recessed. You'll likely need to use a paperclip, SIM Eject tool, or other small pinpoint to press this button.
Upon pressing and holding the back button you'll feel a short vibration, continue to hold both buttons until you feel a longer vibration which indicates the factory reset is complete. After this you can release all buttons and re-pair it to your device.
Der Guide war gut, doch fehlte zum Lösen meiner Pairingprobleme noch das Löschen des GO Plus+ in den in-game Einstellungen von Pokémon GO als wichtiger Zusatz.
I feel the first vibration but I hold it for like 2 minutes and it doesn’t vibrate again. I am trying to factory reset it because it doesn’t work and I’m trying to see if the factory reset will work
Did you fix it?
I'm having the same issue, I believe mine is related to the battery not being charged enough to do anything. Not sure how I can get a discharged battery to start charging though.
