When a Chromebook is plugged into an outlet with a working adapter, but the device will neither charge or power on, this is a sign that the charging port is damaged and needs to be replaced. This guide shows how to replace a defective charging port for a Poin2 Chromebook 11.
Power down the Poin2 Chromebook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Insert a 1cm-wide plastic opening tool between the base and top frame.
Pry (up and down) around the entire border of the Chromebook to separate.
Use your hands to gently lift the base away from the frame.
Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
Remove the six 4mm screws using a Phillips #0 screwdriver.
Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
Pry the metal hinge up, until it sits perpendicular to the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently pull the charging port out of the frame.
Have a chrome book 11 C81C13 / made 2019 . The port is captive"? Connected to almost everything and wifi etc; function's work"! Network on mobile data work “ yet if I try to connect the mobile network on the cell phone ? It with bring all function's displaying that there is signal frequency's etc but the display of the actual funtion. [ Internet does not appear on the computer screen ! ] If I go into a business or use some one other fell mobile data it work's ?. Recommendations".
Great, Now where can I find this part to fix my laptop???
where do I buy the new port???
Rubber feet at the base DO have screws. I broke mine not knowing this.
Marty - crwdns2934203:0crwdne2934203:0
