Plum Optimax 10 Speaker Replacement
  1. Plum Optimax 10 Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plum Optimax 10 Speaker Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plum Optimax 10 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Speaker Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plum Optimax 10 Speaker Replacement, Motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
  4. Plum Optimax 10 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once screws are removed, carefully remove the motherboard out of encasing.
  5. Plum Optimax 10 Speaker Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plum Optimax 10 Speaker Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove electrical tape placed around the battery to keep it in place.
  6. Plum Optimax 10 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plum Optimax 10 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger as a wedge underneath the battery to assist in removal.
    • Once loosened with the spudger, the battery is now removed from the device.
    • Always use a plastic opening tool or nylon spudger to remove batteries. Metal tools can puncture a battery and potentially catch on fire.
  7. Plum Optimax 10 Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the top side of the motherboard (where the black and red wires are), locate and look closely for the "SPK1" lead.
    • Use a pair of wire cutters to clip the wires from the "SPK1" lead.
    • The speaker will pop out of its place and use the wire cutters to remove the wires connected from "SPK1" from the speaker.
  8. Plum Optimax 10 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the wires are located, strip 2mm of the rubbing casing around the top of the wire for the black and red wires. You need to see the aluminum inside.
    • You only need enough aluminum exposed so that you can solder the wires to its respective contact plate.
  9. Plum Optimax 10 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, gently make a connection with solder to the red wire while also making contact to the right contact plate of the speaker.
    • Repeat for black wire for contact plate on speaker.
  10. Plum Optimax 10 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the bottom of the black and red wire by the motherboard.
    • Make a connection with the solder to the board where the black wire is on the negative contact.
    • Connect the red wire to the positive contact on the motherboard and solder.
    • Be careful not to hold the solder iron on the board for an extended period of time. The board could be burned and permanently damaged.
Michael Glennon Graupner
crwdns2935283:010/03/19crwdne2935283:0
289 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G17, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G17, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S1G17
crwdns2942667:0crwdne2942667:0 137
