Playstation Controller Fast Fix
crwdns2869540:0crwdne2869540:0: 8,2 тыс.
43
239
1 032
8 194
crwdns2955950:0crwdne2955950:0: 3
crwdns2960004:02crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 15 - 20 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
This guide provides a quick and practical fix for common controller issues, such as unresponsive buttons or minor stick problems. It emphasizes simple steps, minimal tools, and efficiency. Whether you're dealing with early signs of wear or a sudden malfunction, this fast fix aims to get your controller back to working condition without the need for costly replacements.
    1. Playstation Controller Fast Fix, Power Off and Disconnect: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn off the controller and disconnect it.
    2. Playstation Controller Fast Fix, Gather Tools: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Prepare tools including a precision screwdriver set, plastic pry tool, tweezers, isopropyl alcohol, and cotton swabs.
    3. Playstation Controller Fast Fix, Remove Outer Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate and remove all screws from the controller casing using a screwdriver. top and bottom.
    4. Playstation Controller Fast Fix, Open the Controller Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully pry open the controller using a plastic tool to avoid damaging components.
    5. Playstation Controller Fast Fix, Disconnect Internal Components: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently detach the battery and ribbon cables to access the motherboard, and then unscrew the motherboard retainer(black cover)
    6. Playstation Controller Fast Fix, Locate the Analog Stick Module: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the joystick assembly attached to the circuit board. Note: look hard for this one. It's a bit small
    7. Playstation Controller Fast Fix, Clean the Potentiometers: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply isopropyl alcohol to the base of the analog stick and rotate it to remove dirt and other stuff. Note: be careful on how hard you clean with the swabs, and don't apply too much rubbing alcohol.
    8. Playstation Controller Fast Fix, Reassemble and Test: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Playstation Controller Fast Fix, Reassemble and Test: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Reconnect all components, close the controller, and test it to ensure the stick drift is resolved. Note: since the battery was removed during the procedure, charging the controller is a must after putting it back together.
Aaron Ruiz
crwdns2935283:004/07/26crwdne2935283:0
296 crwdns2915208:0crwdne2915208:0
How can i reconect my controler back to PS 4 ?????
Iosua Padurean - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 43
crwdns2936753:07crwdne2936753:0 239
crwdns2936753:030crwdne2936753:0 1,032
crwdns2959996:0crwdne2959996:0 8,194
