Playstation Classic Power Button Replacement
  1. Playstation Classic Power Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the console so its back is facing up.
  2. Playstation Classic Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 8mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement, Power Button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the motherboard, position the casing so that the back of the power button is visible.
    • Use a spudger to apply pressure inward on the three plastic clips.
    • This will loosen the button enough to remove it from its position.
  8. Playstation Classic Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Power Button Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the casing to its front and remove the loose button with your hand.
    • Leave the spring in its original position.
To reassemble your device, follow these instructions in reverse order.
Maxwell Webb
crwdns2935283:004/22/19crwdne2935283:0
703 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G8, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G8, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G8
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 3,282
