Playstation Classic Open Button Replacement
    1. Playstation Classic Open Button Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the console so its back is facing up.
    2. Playstation Classic Open Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 8mm screws using the Phillips #00 screwdriver.
      • Make sure to keep your screws together in a secure location to avoid misplacement.
    3. Playstation Classic Open Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
    4. Playstation Classic Open Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
      • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
      • Keep track of your screws once they are removed.
    5. Playstation Classic Open Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
    6. Playstation Classic Open Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
      • Pull the metal casing off the motherboard.
      • Remember to be gentle when handling the motherboard.
    1. Playstation Classic Open Button Replacement, Open Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement, Open Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement, Open Button: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the motherboard using the previous guide and isolate the top shell of the casing.
      • Use the Spudger to apply pressure inwards on the three plastic clips highlighted in the red circles.
    2. Playstation Classic Open Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After all three clips are pushed in, apply pressure on the cylindrical piece circled in red.
      • Push softly on the button till a small gap is created on the other side.
      • You are not trying to fully remove the Open Button in this step.
    3. Playstation Classic Open Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Playstation Classic Open Button Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the black spudger to softly pry out the open button from the top of the casing.
      • Once enough of a gap has been created, use your fingers to grab and slowly remove the open piece.
      • An unrestrained spring is under the open button and can fall out easily. To avoid losing the spring, complete this step on a flat surface and be gentle while removing the open button.
Maxwell Webb
crwdns2935283:004/22/19crwdne2935283:0
709 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G8, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G8, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G8
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 2,078
