This guide will walk you through how to replace a faulty motherboard in the Sony Playstation Classic. Make sure to be gentle when handling your motherboard.
Flip the console so its back is facing up.
Remove the five 8mm screws using the Phillips #00 screwdriver.
Remove the back plate from the rest of the console using your hands or the Jimmy tool.
Unscrew the motherboard's four 6mm screws with the Phillips #00 screwdriver.
Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
Pull the metal casing off the motherboard.
where do you get a ps1 classic mini motherboard ?
You would probably be cannibalizing a broken PS1 Classic for its motherboard. Perhaps "Parts Only."
