PlayStation TV Thermal Pad Replacement
  1. PlayStation TV Thermal Pad Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic spudger to pry up the bottom piece of the case to release the clips.
  2. PlayStation TV Thermal Pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6 mm Phillips screws.
    • Remove the two Phillips #0 screws.
  3. PlayStation TV Thermal Pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the heat shield using the plastic opening tool.
    • Slide the tool around the edges until the shield is free.
  4. PlayStation TV Thermal Pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the last 6mm Phillips #0 screw from the motherboard.
  5. PlayStation TV Thermal Pad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry up gently on the motherboard, and remove it.
  6. PlayStation TV Thermal Pad Replacement, Thermal Pad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement, Thermal Pad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the old thermal pad with an ESD safe tool, like a Jimmy.
  7. PlayStation TV Thermal Pad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation TV Thermal Pad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wipe down the area where the old thermal pads were located with rubbing alcohol.
    • It is important that the area be as clean as possible.
Theodore Hesse
crwdns2935283:001/22/16crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
IUPUI, Team 3-1, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 3-1, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S3G1
Photos for steps 6 through 9 will be posted soon!
Luk Davis - crwdns2934203:0crwdne2934203:0
Do you replace the thermal pad? Your directions do not state where to do this, and if so what part and size do you recommend?
Daimonion - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,115
