Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Once the device is opened, lift the battery out of the black plastic holder.
You can disconnect the back/trigger assembly ribbon cable at this point by proceeding to Steps 13/14 (without the other steps for disassembly as they are unnecessary for replacing just the trigger).
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Gently pull out the small grey cylindrical piece (vibrator).
Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
Gently pull on the white piece connecting the battery and the connector.
Remove the five 1.2 mm screws from upper portion of the controller.
Remove the two 1.2mm Phillips #1 screws.
Cautiously remove the circular white piece at the top without removing the LED inside.
Accidentally ripped this off as my PS Move is a different model, any chance this could be fixed using like jumper wires or not?
Remove the blue strip that is connected to the trigger button from the motherboard.
Remove the trigger button from the controller.
Remove the LED light by removing the white strip.
This step is destructive and simply breaks the LED solder joints!!!
WTF, you literally broke the soldered ribbon cable.
Remove the motherboard from the plastic case.
crwdns2917034:0crwdne2917034:0
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
