PlayStation 4 Slim Thermal Paste Replacement
crwdns2936621:0crwdne2936621:0
  1. PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the panel next to the ports by sliding it to the right.
    • Use a Philips PH1 screwdriver to remove the screw.
  2. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black ribbon on the side of the PS4 to remove the hard drive.
  3. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Peel off the plastic warranty sticker next to the three ports on the side of the console.
    • Use a T8 Torx security screwdriver to remove the screw.
  4. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you.
    • Remove the cover by prying the two corners and then sliding it back.
    • This step will require some force and you will hear clicking sounds as the cover is coming off.
  5. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove this screw.
  6. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three T8 Torx security screws.
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Lift and remove the metal panel after unscrewing.
  7. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power supply completely by disconnecting the wire.
  8. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the PS4 to view the metal paneling.
    • Lift the black clip on the largest connection to remove it.
    • Disconnect the wire by pulling it back with a little bit of force.
    • By pulling on the blue tabs gently you are able to remove the connections.
    • Gently lift the black wire to disconnect from the motherboard.
  9. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove all screws.
    • After unscrewing, remove the metal panel to access the motherboard.
    • Removing the metal panel may require some force but do not pull up too hard as you may have missed a screw.
  10. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove two screws.
    • Unplug the wire by pulling firmly.
    • Lift the metal brace with your fingers to expose the motherboard.
  11. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left.
    • Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Both steps may require multiple repetitions.
  12. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface.
    • Let the thermal paste rest for 10 minutes before reassembly.
  13. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two screws.
  14. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the console.
    • Use a Phillips #0 screwdriver to remove the screw.
  15. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the metal panel and on the back the radiator is located.
    • Clean the radiator by using a brush and a compressed air can.
  16. PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Thermal Paste Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Clean the fan by using a brush and a compressed air can.
crwdns2935229:0109crwdne2935229:0
Muhammad Saif Khan
crwdns2935283:007/07/20crwdne2935283:0
2.363 crwdns2915208:0crwdne2915208:0
York University, Team S1-G7, Allen Summer 2020 crwdns2935289:0York University, Team S1-G7, Allen Summer 2020crwdne2935289:0
YORK-ALLEN-SU20S1G7
crwdns2947412:014crwdne2947412:0
Hey, can I use this for a original “fat” ps4?
thanks
notle159 - crwdns2934203:0crwdne2934203:0
the original fat ps4 uses a different design than the slim one
alden dufresne -
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Nicholas Pratt III - crwdns2934203:0crwdne2934203:0
Use a brush at the same time with a vacuum cleaner to remove the dust, then, a slightly damp cloth to clean the blades.
Raul Alberto Chavez Romero -
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws 😂😂😂
Ferrera_Gabs - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 86
crwdns2936753:07crwdne2936753:0 624
crwdns2936753:030crwdne2936753:0 2,556
crwdns2942667:0crwdne2942667:0 165,758
