PlayStation 4 Slim Fan System Replacement
    1. PlayStation 4 Slim Fan System Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the plastic warranty sticker next to the three ports on the side of the console.
      • Remove the warranty sticker by peeling it off with any kind of spudger.
      • Removing the warranty sticker will NOT cause your warranty to be null and void.
    2. PlayStation 4 Slim Fan System Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
    3. PlayStation 4 Slim Fan System Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
      • Pry up on the two corners that are facing you with your fingers.
      • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
      • Remove the bottom cover by sliding it towards the back corners and lifting up.
    1. PlayStation 4 Slim Fan System Replacement, Power Supply: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Power Supply: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Power Supply: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
      • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
      • Remove the top cover by sliding it towards the back corners and lifting up.
    2. PlayStation 4 Slim Fan System Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
      • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    3. PlayStation 4 Slim Fan System Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 16mm Philips screws holding the power supply in place.
    4. PlayStation 4 Slim Fan System Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    5. PlayStation 4 Slim Fan System Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    6. PlayStation 4 Slim Fan System Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the Playstation 4 Slim onto its back.
      • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. This screw holds the power supply in place
    7. PlayStation 4 Slim Fan System Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
      • Lift the power supply up and onto its back on the metal sheet using your hands.
    8. PlayStation 4 Slim Fan System Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
      • Remove the power supply completely by grabbing and lifting up with your hands.
    1. PlayStation 4 Slim Fan System Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
    2. PlayStation 4 Slim Fan System Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the two wires connected to the bottom of the motherboard.
      • Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
    3. PlayStation 4 Slim Fan System Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the device to the backside.
      • Unscrew and remove 14x (19x for CUH-21xx) 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
      • Unscrew and remove 8x (7x for CUH-21xx) 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
      • Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    4. PlayStation 4 Slim Fan System Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
      • Skip this step for the CUH-21xx, as those screws were removed in the previous step.
    5. PlayStation 4 Slim Fan System Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the white wire connected to the corner of the top of the motherboard.
      • Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
      • Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
    6. PlayStation 4 Slim Fan System Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the connections by pulling out on the blue tabs with your fingers.
      • Flip up the black clip on the largest tab with your finger before removing it.
      • Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
    7. PlayStation 4 Slim Fan System Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
      • You may need to wiggle the plate a bit to get it loose before you lift it out.
      • Do not lose any of the black pads attached to the motherboard while performing this step.
    8. PlayStation 4 Slim Fan System Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
      • Remove the small metal plate by grabbing it with your fingers and lifting up.
    9. PlayStation 4 Slim Fan System Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove this wire connection by firmly grasping it with tweezers and pulling out.
      • This might require a bit of force to disconnect, but be sure not to break any of the wires.
    10. PlayStation 4 Slim Fan System Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
      • You may need to wiggle the board a bit to get it loose before you remove it.
    1. PlayStation 4 Slim Fan System Replacement, Fan System: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement, Fan System: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew and remove the six 4.0mm screws using a PH00 screwdriver with a counter-clockwise motion.
    2. PlayStation 4 Slim Fan System Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the metal plate by grabbing the edges and lifting up with your hands.
    3. PlayStation 4 Slim Fan System Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew and remove the two 40 mm screws using a PH00 screwdriver with a counter-clockwise motion.
    4. PlayStation 4 Slim Fan System Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Slim Fan System Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the fan system by grabbing the edge of the top metal plate and lifting up with your hands.
crwdns2935229:086crwdne2935229:0
Harry Koos
crwdns2935283:001/24/18crwdne2935283:0
6,634 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S19-G4, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S19-G4, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S19G4
Thank you so much for this guide! It was very helpful!
David Rodriguez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Deine Schrauben großen machen gar kein Sinn du hast mehr verschiedene Schrauben als es gibt
Andre Hollmann - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My PS4 “Slim” is quite different internally than the one shown. But regardless, this guide is an excellent resource for us diy’ers. And don’t forget any parts when reassembling, like I did. Took four tries to get everything back where it belonged. And man, was it dusty in there! Regular cleaniings are a must.
Patrick Ogren - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My ps4 slim is different it has some extra parts, now I don’t know how to put it back, hahahahahhahaha
Lancelotte Fabros - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This guide gets you 90% of the way there. Some really important pieces are missing though, primarily:
- How you dont need to unplug the power supply cable from the motherboard, you can just unhook it from the plastic clips on the case.
- It never mentions cleaning the old Thermal Paste off the heatsink + cpu and replacing with a new dab.
Both of these are essential for a proper tear-down. If you dont replace the thermal paste, your PS4 is guaranteed to break down irreparably in the future. I had to know or discover them for myself. Please, please update this guide with that info.
Zoey Schlemper - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 60
crwdns2936753:07crwdne2936753:0 512
crwdns2936753:030crwdne2936753:0 2,402
crwdns2942667:0crwdne2942667:0 196,972
