PlayStation 4 Pro Power Supply Unit Replacement
  1. PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by flipping the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the single Phillips #0 screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove the five screws.
    • Two 31mm screws.
    • Three 10mm screws.
    • Remove the metal plate.
  5. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console to its back once again.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
    • Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
  6. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx security screwdriver to remove the two 10mm silver screws from the metal plate.
  7. PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Power Supply Unit Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console over to continue working on the top side.
    • Place fingers underneath edge of power supply unit on both sides and pull straight up.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
crwdns2935229:040crwdne2935229:0
Ashlyn Chow
crwdns2935283:004/25/17crwdne2935283:0
3 590 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G5, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G5, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G5
crwdns2935297:049crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Thank you soooo much for helping me save my ps4 pro guys! At the moment I love you like no one before! ;D
Fayce D D - crwdns2934203:0crwdne2934203:0
Can you go further in your tear-down and show us how to open up the power supply without breaking the PSU plastic case? Thanks. ^_^
Matt - crwdns2934203:0crwdne2934203:0
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
joseph fish - crwdns2934203:0crwdne2934203:0
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Tomás Javier - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 141
crwdns2936753:030crwdne2936753:0 660
crwdns2942667:0crwdne2942667:0 102,551
