PlayStation 4 Pro Heat Pipe Replacement
  1. PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
  11. PlayStation 4 Pro Heat Pipe Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
  12. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
    • Grip the X-shaped retaining bracket and lift straight up.
  13. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
  14. PlayStation 4 Pro Heat Pipe Replacement, Heat Pipe: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement, Heat Pipe: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
  15. PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Heat Pipe Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
crwdns2935229:045crwdne2935229:0
Thomas
crwdns2935283:004/26/17crwdne2935283:0
4,083 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G5, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G5, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G5
crwdns2935297:049crwdne2935297:0
Ist es schlimm, wenn man die 2 schrauben von schritt 14 vergessen hat zum verschrauben?
AxoN z - crwdns2934203:0crwdne2934203:0
Can anyone explain what are those 5 blocks near heatsink as mine are broken when I open it 2 blocks have converted into dust plz help
rajatagg41 - crwdns2934203:0crwdne2934203:0
This guide doesn't tell how to change the Heat Pipe on the later models. In my 72xx version, the Heat Pipe can be seperated from the chassis plating with 4 screws (ph#1)
TdG - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 431
crwdns2942667:0crwdne2942667:0 74,503
