PlayStation 4 Pro Fan Replacement
    1. PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the console upside down.
      • Use your finger to pull and snap off the plastic cover over the hard drive.
    2. PlayStation 4 Pro Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
      • Pull the hard drive caddy straight out.
    1. PlayStation 4 Pro Fan Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the console right side up.
      • Grip the two corners located at the front of the device.
      • Pull upwards until a loud click is heard.
      • This may require a lot of force, so do not be afraid to get a little rough with your console.
      • After both corners detach, slide the cover backwards and lift off.
    2. PlayStation 4 Pro Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
      • Two 31mm screws.
      • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
      • Remove the metal plate by pulling it up.
    3. PlayStation 4 Pro Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the console over so the bottom is facing up.
      • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
      • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
    4. PlayStation 4 Pro Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
      • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
      • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
      • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
    5. PlayStation 4 Pro Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the white fan connector straight out of the yellow mount on the motherboard.
    6. PlayStation 4 Pro Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull out the five small, blue low profile cables connected to the metal plate.
      • Lift the retaining flap on the ZIF connector of the large ribbon cable.
      • Pull the large ribbon cable from its socket.
      • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
    7. PlayStation 4 Pro Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull up and remove the metal plate.
    8. PlayStation 4 Pro Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the console over to continue working on the top side.
      • Pull up on the power supply unit and set it on the console.
      • Be careful not to pull too far, the assembly is still connected at one point.
      • Grip the connector behind the power supply and pull straight out.
    1. PlayStation 4 Pro Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
      • Carefully flip the console over so the bottom is facing up.
      • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
      • Use a plastic opening tool to remove the metal plate with the X-like shape.
    2. PlayStation 4 Pro Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
      • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
      • Grip the X-shaped retaining bracket and lift straight up.
    3. PlayStation 4 Pro Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
      • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
    1. PlayStation 4 Pro Fan Replacement, Heat Pipe: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Heat Pipe: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
    2. PlayStation 4 Pro Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 4 Pro Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the metal plate that is connected to the heat pipe straight up to remove it.
    1. PlayStation 4 Pro Fan Replacement, Fan: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Fan: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 4 Pro Fan Replacement, Fan: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the two 6mm screws on the fan.
      • On 7200-series models these screws will be on the right of the fan.
      • Grab the fan and lift up to remove it.
crwdns2935229:0130crwdne2935229:0
Thomas
crwdns2935283:004/26/17crwdne2935283:0
4,186 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S21-G5, Livingston Spring 2017 crwdns2935289:0Cal Poly, Team S21-G5, Livingston Spring 2017crwdne2935289:0
CPSU-LIVINGSTON-S17S21G5
crwdns2935297:084crwdne2935297:0
crwdns2947412:015crwdne2947412:0
Danke für die Anleitung. hat alles super geklappt. Bloß beim letzten Schritt ist die Schraube vom Lüfter nicht oben links sondern unten rechts. Mfg
Camorrista31 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks for the guide. Very comprehensive.
Paul Swinglehurst - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’m clueless with electronics but my PS4 was on its death throes with overheating. I read this guide and watched the video (coffee break included) and got to work. The only trouble I had was that my husband (he’s a good guy normally) decided to help and used too big pliers and broke the connector between the power supply and PS4. Ok, so 5 days wait for replacement. I replaced the fan, thermal paste, and pads and put it back together (shaking like a leaf in a hurricane). It’s quiet and works thanks to ifixit.com. Thank you so much!
K. Birks - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This was super helpful! For the power supply, I was trying to pull at the socket the cable was plugged into (same color plastic). I think it would have worked better just wiggling the cable.
Also, T8 worked fine, but putting it back together, I noticed T9 was better fit, so if you have a T9, use that instead. After cleaning and repasting, it’s so much quieter. Thanks!
Phil - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Great guide. I did have a little difficulty getting the power supply connector removed, but I tried to be patient and eventually got it. Thanks!
JTG - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 53
crwdns2936753:07crwdne2936753:0 307
crwdns2936753:030crwdne2936753:0 1,387
crwdns2942667:0crwdne2942667:0 199,654
