PlayStation 3 Blu-ray Disc Drive Replacement
  1. PlayStation 3 Blu-ray Disc Drive Replacement, Smart Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 3 Blu-ray Disc Drive Replacement, Smart Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Blu-ray Disc Drive Replacement, Top Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Blu-ray Disc Drive Replacement, Blu-ray Disc Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the Blu-ray power cable from the motherboard.
    • Pull the connector straight up and out of its socket.
  8. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the Blu-ray drive from the edge nearest the power supply and rotate it away from the chassis enough to access its ribbon cable.
  9. PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 3 Blu-ray Disc Drive Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the Blu-ray drive from the PS3.
    • If replacing the Blu-ray drive, transfer the power cable to your new drive.
crwdns2935229:0156crwdne2935229:0
Walter Galan
702,835 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
crwdns2947412:016crwdne2947412:0
Most helpful. Thx need to buy parts.and tools needed to fix game game. Were to buy ?
The Unknown Soldier - crwdns2934203:0crwdne2934203:0
Not sure myself, need one too. Look under comments section under ps3 laser replacement for more info. They are supposed to sell them on this website but I think they are still out.
Brian Parks - crwdns2934203:0crwdne2934203:0
Can I use any fat PS3 blu-ray drive in a fat PS3 or do I need a certain on????? I have a 80gb fat PS3
tonyhb - crwdns2934203:0crwdne2934203:0
No, you need a certain one + you have to take off the daughter board from your old drive and put it on the new one.
aangelcg -
crwdns2936751:024crwdne2936751:0 24
crwdns2936753:07crwdne2936753:0 173
crwdns2936753:030crwdne2936753:0 824
crwdns2942667:0crwdne2942667:0 406,932
