Follow this guide to replace the power supply on your PlayStation 2 Slimline.
Turn off your PlayStation 2 and remove the disc and Memory Card.
Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
Locate the six covers.
Two are located underneath the feet.
One cover is located underneath the Void sticker.
Remove the Void sticker with a Spudger and some cleaning alcohol
Remove the covers by using either a Spudger, Opening Picks or your fingernail.
Remove the six Phillips #1 screws with a screwdriver.
The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
Separate the two halves.
Remove the Phillips screw from the power supply.
Remove the power supply connector from the motherboard.
To separate the connector from its socket, squeeze the tab against the connector, and pull the connector straight up from the socket.
Lift the power supply straight up and out of the PS2.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
I remember i was open the PS2 for cleaning but when i cleaning the power supply, my sister plugged it than I got an electric shock. 🤣🤣🤣
