Follow this guide to replace the fan of your PlayStation 2 Slimline.
Turn off your PlayStation 2 and remove the disc and Memory Card.
Turn over the PlayStation 2 and put it on a soft surface (e.g. a towel).
Locate the six covers.
Two are located underneath the feet.
One cover is located underneath the Void sticker.
Remove the Void sticker with a Spudger and some cleaning alcohol
Remove the covers by using either a Spudger, Opening Picks or your fingernail.
Remove the six Phillips #1 screws with a screwdriver.
The screws on the right are a bit deeper inside the shell as like the rest but are the same size.
Separate the clips at the front and the overhanging side from their mounting using a Prying Tool.
Separate the two halves.
Pull the ribbon cable straight out from the socket.
Remove three Phillips #0 screws securing the fan.
Lift the fan straight up and out of the PS2.
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0MrJuliancrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
