PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sticker and then remove the 6th foot.
  4. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    It took force to open it, but i broke a plastic pin where the screws enter
    Vasco Mateus - crwdns2934203:0crwdne2934203:0
    You can use a pick to get the thin edge up without breaking anything.
    Mira Mogzec - crwdns2934203:0crwdne2934203:0
  6. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, IR Sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, IR Sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, IR Sensor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the IR sensor on the motherboard. Then, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
    am I able to buy a replacement IR sensor????
    I CantFixIt - crwdns2934203:0crwdne2934203:0
  8. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Clock Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Clock Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Clock Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  9. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the battery up from the battery compartment using a spudger.
  10. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Fan: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the fan component of the motherboard of the PS2.
    • With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  11. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the terminal (white covering) to the red and yellow cords from the motherboard to the fan with the use of tweezers.
  12. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
    • They are located off the curved edge of the fan.
    • Once you have removed the three screws, you are able to remove the fan from the PS2.
  13. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Optical Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Optical Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the optical drive on the motherboard.
  14. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  15. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  16. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  17. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the optical drive away from the motherboard.
  18. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement, Metal Chassis: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the metal plate that is attached to the back of the motherboard.
  19. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the six 1.6mm screws that mount the metal plate to the motherboard.
    Red circles for the screws are wrong. This guide for the 7500x A to be re-reviewed.
    ravenrue - crwdns2934203:0crwdne2934203:0
  20. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew all six 1.6mm screws that mount the metal plate to the motherboard.
  21. PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Slimline SCPH-7500x Metal Chassis Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the metal plates from both the top and bottom of the motherboard.
Jared Hirata
crwdns2935283:004/09/13crwdne2935283:0
941 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-4, Regan Spring 2013 crwdns2935289:0Cal Poly, Team 17-4, Regan Spring 2013crwdne2935289:0
CPSU-REGAN-S13S17G4
crwdns2935297:028crwdne2935297:0
Not the IR reader, it's the power/reset button.
Static - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,756
