Replace your PlayStation 2's fan.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
Peel the warranty sticker (located next to the main power switch) straight away from the case.
Lift the top cover off the bottom case.
Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
If you have a 5000x model, then the power and reset buttons are attached to the console, not the lid. Therefore there won’t be a cord
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
Gently lift the controller port board out of its recess within the bottom case.
Pull the controller port ribbon cable straight away from its socket on the controller port board.
Remove the controller port board out of the bottom case.
El conector del flex del modulo de conectores de los mando y las memory card no va a presión, para volver a colocarlo, hay que abrirlo.
Controller is detached can we fix it?
The clip which holds the controller is broken
Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
Pry and remove the expansion bay cover away from its posts on the bottom case.
If there is a harddrive in the system place switch on off position before removing and reinstalling because it may blow the fuse that runs the harddrive!
Lift the motherboard assembly from its front edge and remove it from the lower case.
Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
If you have a 5000x model, then the power supply will be flipped upside down (or right side up). the screws are in the same positions
Lift the expansion bay cage up off the motherboard assembly.
Pull the power board connector straight to lift it out of its socket on the power board.
Remove the heat shield from the motherboard assembly.
Remove the small white piece of tape (highlighted in red) that holds the fan cable connected to the fan.
Pull the fan cable straight up from its socket on the motherboard.
Remove the fan and power switch assembly by pulling it out the bottom case.
Remove the fan from the power switch assembly.
Remove the power switch from its recess within the fan/power switch holder.
Can someone tell me how to hook my fan back to my p2 the connector got snatched out
crwdns2935229:037crwdne2935229:0
crwdns2944067:010crwdne2944067:0
what about on fixing when the unit doesn't turn back on? Replaced the ribbon cable after blowing out the dust, reassemble the unit and it didn't turn back on no green or red light's.
You should check to c if the side with the blue is on the top @ the silver on the bottom
What do I do if the fan connector to motherboard has a broken leg? Can I rewire the connector to other points to solder to the board?
What about the slim model? Is there a guide for that?
I have a question about this I just want to clean off the fan not replace it how do I do
A nice ol' bottle of compressed air will do the trick. You have two options, either open the console up and give it a spurt from the inside, or be lazy like me and shoot it from the outside! Cheers!
When you’ve gotten to the fan, instead of unplugging and removing the fan, clean it with cotton swaps dipped in isopropyl alcohol that is 90% or higher.
I tried replacing the fan with a new one but it still doesn’t spin, I guess the fuse popped for some reason so I just got a usb fan and drilled holes at the top of my console and stuck the fan there with cable ties
did you ever fix your fan?
الزر الاحمر لا يعمل مع انة متصل بالكهرباء
Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
Tristan - crwdns2934203:0crwdne2934203:0
Ich möchte daraufhin weisen, daß es bei der SCPH-50004 zwei verschiedene Schraubabdeckungen gibt.
4x Kreuzförmig 4x rechteckig
Sowie eine silberne schraube die sich an der unterseite aufhöhe des Reset-Knopfes befindet.
Christian Lehnhardt - crwdns2934203:0crwdne2934203:0
