PlayStation 2 Fan Replacement
  1. PlayStation 2 Fan Replacement, Top Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Fan Replacement, Top Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Fan Replacement, Top Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
    Tristan - crwdns2934203:0crwdne2934203:0
    Ich möchte daraufhin weisen, daß es bei der SCPH-50004 zwei verschiedene Schraubabdeckungen gibt.
    4x Kreuzförmig 4x rechteckig
    Sowie eine silberne schraube die sich an der unterseite aufhöhe des Reset-Knopfes befindet.
    Christian Lehnhardt - crwdns2934203:0crwdne2934203:0
  2. PlayStation 2 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    If you have a 5000x model, then the power and reset buttons are attached to the console, not the lid. Therefore there won’t be a cord
    ARandomGuy231 - crwdns2934203:0crwdne2934203:0
  5. PlayStation 2 Fan Replacement, Power Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Fan Replacement, Power Board: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. PlayStation 2 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. PlayStation 2 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
    El conector del flex del modulo de conectores de los mando y las memory card no va a presión, para volver a colocarlo, hay que abrirlo.
    Marcos Morán - crwdns2934203:0crwdne2934203:0
    Controller is detached can we fix it?
    The clip which holds the controller is broken
    sravan kumbum - crwdns2934203:0crwdne2934203:0
  8. PlayStation 2 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. PlayStation 2 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
    If there is a harddrive in the system place switch on off position before removing and reinstalling because it may blow the fuse that runs the harddrive!
    stephen harrison - crwdns2934203:0crwdne2934203:0
  10. PlayStation 2 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. PlayStation 2 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
    If you have a 5000x model, then the power supply will be flipped upside down (or right side up). the screws are in the same positions
  12. PlayStation 2 Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the expansion bay cage up off the motherboard assembly.
  13. PlayStation 2 Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
  14. PlayStation 2 Fan Replacement, Fan: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The transparent piece of plastic located underneath the power supply recess in the motherboard assembly is the heat shield.
    • Remove the heat shield from the motherboard assembly.
    • Dislodging the heat shield can be a bit stubborn, so it may take a little finessing to get it free.
  15. PlayStation 2 Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PlayStation 2 Fan Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • We can now remove the fan and main power switch assembly.
    • Remove the small white piece of tape (highlighted in red) that holds the fan cable connected to the fan.
    • Pull the fan cable straight up from its socket on the motherboard.
    • The fan and power switch are now free from the rest of the PlayStation 2.
    • Remove the fan and power switch assembly by pulling it out the bottom case.
  16. PlayStation 2 Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan from the power switch assembly.
    • The fan simply slides out of the top along its track.
  17. PlayStation 2 Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power switch from its recess within the fan/power switch holder.
    • The power switch simply slides out just like the fan.
    Can someone tell me how to hook my fan back to my p2 the connector got snatched out
    Trudy Green - crwdns2934203:0crwdne2934203:0
You’ve successfully replaced the PlayStation 2 fan! Plug the console back in and power it on to ensure the fan is spinning normally. To reassemble your device, follow these instructions in reverse order.
crwdns2935229:039crwdne2935229:0
crwdns2935103:0crwdne2935103:0
jwyoung
crwdns2935283:011/04/09crwdne2935283:0
2,968 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-1, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 19-1, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S19G1
crwdns2935297:035crwdne2935297:0
crwdns2947412:011crwdne2947412:0
what about on fixing when the unit doesn't turn back on? Replaced the ribbon cable after blowing out the dust, reassemble the unit and it didn't turn back on no green or red light's.
themidnightdj - crwdns2934203:0crwdne2934203:0
You should check to c if the side with the blue is on the top @ the silver on the bottom
Trudy Green -
What do I do if the fan connector to motherboard has a broken leg? Can I rewire the connector to other points to solder to the board?
RJ Weber - crwdns2934203:0crwdne2934203:0
What about the slim model? Is there a guide for that?
the stronk green bean - crwdns2934203:0crwdne2934203:0
I have a question about this I just want to clean off the fan not replace it how do I do
Miranda Decker - crwdns2934203:0crwdne2934203:0
A nice ol' bottle of compressed air will do the trick. You have two options, either open the console up and give it a spurt from the inside, or be lazy like me and shoot it from the outside! Cheers!
Jordan Schivek -
When you’ve gotten to the fan, instead of unplugging and removing the fan, clean it with cotton swaps dipped in isopropyl alcohol that is 90% or higher.
Christopher -
I tried replacing the fan with a new one but it still doesn’t spin, I guess the fuse popped for some reason so I just got a usb fan and drilled holes at the top of my console and stuck the fan there with cable ties
Romero-Kyun - crwdns2934203:0crwdne2934203:0
did you ever fix your fan?
brandon diehm -
الزر الاحمر لا يعمل مع انة متصل بالكهرباء
ahmed naguib - crwdns2934203:0crwdne2934203:0
Hallo Herr ich habe eine Frage haben Ersatzeile Play Station 2
Nico Müller - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 123
crwdns2936753:030crwdne2936753:0 587
crwdns2942667:0crwdne2942667:0 109,255
