This guide is only to replace the PSV 100x and maybe the PSV 200x Analog Sticks,Cap,Button.
This guide is only to replace the Stick button
Open the little holders
then carefully lift the metal plate
Take out the small Springs and pry it open . I marked the direction .
Lift up this metal holder, don´t bend it.
Then with tweezers detach the white plastic. It holds the Analog cap.
One end of the white plastic is magnetic. Do not damage it
Turn the cap and replace it with a new one.
* If Sony did not did this thing with the Analog Cap turning we could simply pull out the Cap and place a new one.
Assembly is simple like the disassembly :D
crwdns2917034:0crwdne2917034:0
Marked as easy? Does it look harder than it is? Looks like it requires alot of precision
