Plantronics Voyager Legend Earpiece Replacement
  1. Plantronics Voyager Legend Earpiece Replacement, Earpiece: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement, Earpiece: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement, Earpiece: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the soft, plastic earpiece.
    • Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
    • List the soft, plastic earpiece out of its position.
  2. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the earpiece assembly with a heat gun (a hair dryer will work if a heat gun is not available).
    • The heating softens the adhesive that holds the assembly together, and the assembly may need to be reheated to complete the dis-assembly process.
  3. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The two snaps that combine with the adhesive to hold the assembly together are located in the neck of the earpiece unit.
  4. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top half of the earpiece assembly.
    • Use the pointed end of a small, metal Spudger to loosen the two tabs that hold the earpiece assembly together.
    • While glue is soft and snaps are loosened, remove the entire top half of the earpiece housing.
  5. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speaker housing.
    • With the copper backing plate displayed, use the pointed end of a small, metal Spudger to disassemble the speaker housing.
    • Using the pointed end of the small, metal Spudger, lift the copper, backing plate away from the speaker unit.
  6. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use Precision Tweezers to remove the protective screen from the front of the speaker unit.
  7. Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plantronics Voyager Legend Earpiece Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the speaker unit and solder a new unit in place.
    • When disconnecting leads, always disconnect as near as possible to the component being replaced, to allow room for reattachment.
    • Locate the leads that connect to the back of the speaker unit.
    • Disconnect the leads from the back of the speaker unit.
    • Remove the speaker unit, and replace by soldering the leads back into their correct locations.
    • Refer to the iFixit soldering guide for assistance with soldering.
Lewis Certain
crwdns2935283:009/10/15crwdne2935283:0
2.331 crwdns2915208:0crwdne2915208:0
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 crwdns2935289:0USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015crwdne2935289:0
USFSM-STEWART-F15S1G2
crwdns2935297:020crwdne2935297:0
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
albert einstein - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 16,777
