Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement
  1. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Grip: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Macroline: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Body: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
    • Remove the solenoid.
  9. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the board connection with the 2 black wires from the terminal.
    • BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
    • Pull out the wires through the opening in the top of the grip and replace the solenoid.
  10. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement, Solenoid Gasket: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the solenoid gasket manifold, underneath the top half of the body.
  11. Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Geo3 Solenoid Manifold Gasket Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the solenoid gasket manifold by applying pressure with one finger to the part closest to the end of the barrel.
Rett Triplett
crwdns2935283:010/18/13crwdne2935283:0
801 crwdns2915208:0crwdne2915208:0
Clemson, Team 13-6, Benson Fall 2013 crwdns2935289:0Clemson, Team 13-6, Benson Fall 2013crwdne2935289:0
CLEM-BENSON-F13S13G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 672
