Planet Eclipse Etha Bolt O-rings Replacement
  1. Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement, Bolt O-rings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the 1/4" hex key, turn the bolt counterclockwise and remove.
  2. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the bolt tip and spring off of the main assembly.
    • Keep a towel handy, you may get some grease on your hands.
  3. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the casing from the rest of the bolt.
    • Again, you may get some grease on your hands during this step.
  4. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the flat surface shown.
    • Unscrew this portion counter clockwise to remove it.
    • If you're having trouble unscrewing the part, try using a small wrench.
  5. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the threaded cover and slide it away from the spring.
    • The bolt should now be in three pieces.
    • The threaded cover is the same part that you unscrewed in the last step.
  6. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace and lubricate the 9 marked O-rings.
    • O-ring removal will be explained in the next step.
  7. Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Planet Eclipse Etha Bolt O-rings Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the O-ring on the sides.
    • Pinch the O-ring upwards to create a gap between the metal and the ring.
    • Use a small object to slip into the loop and pull the O-ring off gently.
    • We recommend using a small Allen Key for this.
nicholasj6
crwdns2935283:010/14/14crwdne2935283:0
261 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-42, Amido Fall 2014 crwdns2935289:0Cal Poly, Team 10-42, Amido Fall 2014crwdne2935289:0
CPSU-AMIDO-F14S10G42
crwdns2942667:0crwdne2942667:0 2,307
