Place the device face down on a non-scratch surface.
Using a fingernail pry open the back cover off with the bottom left indent.
Using a fingernail, press into the bottom divot and remove the battery from the phone.
Use a spudger or plastic opening tool to pry off the plastic cover.
Use a spudger to lift the ZIF tabs and press-fit connectors free.
Use a spudger to lift the motherboard up and remove it from the device.
Use a spudger to gently pry the volume button off of the phone.
