Photive Hydra Battery Replacement
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement, Battery (Prerequisite): crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • identify the two points that will need soldering.
  9. Photive Hydra Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In this step you will perform the soldering to remove the positive(red) and negative(black) wires).
  10. Photive Hydra Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the solder is removed your battery is now removed and can be replaced with the new battery.
    Why not cut and splice the wires instead of desoldering from the mother board? Seems a lot easier.
    Dan Bird - crwdns2934203:0crwdne2934203:0
Andrew Chase
crwdns2935283:002/09/16crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-3, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 11-3, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S11G3
Battery Replacement of the Photove Loudspeaker PH-BTW55
A very good description and easy to do, but: to replace a Battery to have to use a soldering iron is behind every tecnologie - must be „Made in China". Would I have know this on the first place I never would have bought this and I never will!
Rolf Luebbers - crwdns2934203:0crwdne2934203:0
Why can’t you just cut the wires and then solder the cut wires together rather than de-soldering from the board?
crwdns2942667:0crwdne2942667:0 1,363
