Photive Hydra Battery Replacement
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Photive Hydra Battery Replacement, Battery (Prerequisite): crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • identify the two points that will need soldering.
  9. Photive Hydra Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In this step you will perform the soldering to remove the positive(red) and negative(black) wires).
  10. Photive Hydra Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the solder is removed your battery is now removed and can be replaced with the new battery.
Andrew Chase
crwdns2935283:002/09/16crwdne2935283:0
355 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-3, Cheng Spring 2016 crwdns2935289:0USF Tampa, Team 11-3, Cheng Spring 2016crwdne2935289:0
USFT-CHENG-S16S11G3
Battery Replacement of the Photove Loudspeaker PH-BTW55
A very good description and easy to do, but: to replace a Battery to have to use a soldering iron is behind every tecnologie - must be „Made in China". Would I have know this on the first place I never would have bought this and I never will!
Rolf Luebbers - crwdns2934203:0crwdne2934203:0
Why can’t you just cut the wires and then solder the cut wires together rather than de-soldering from the board?
Dan Bird - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,447
