Use this guide to open up your speaker and remove and replace different components under the front panel.
Remove two 9mm Phillips #0 head screws from the bottom side of the speaker.
Peel back the rubber feet from either side of the base.
Remove four 9mm Phillips #0 head screws from the bottom of the speaker.
Separate the base of the speaker from the upper housing.
Remove four 9mm Phillips #0 head screws from the inside of the speaker case.
Remove all cable connectors from the speaker motherboard.
