Use this guide to replace the battery.
Remove two 9mm Phillips #0 head screws from the bottom side of the speaker.
Peel back the rubber feet from either side of the base.
Remove four 9mm Phillips #0 head screws from the bottom of the speaker.
Separate the base of the speaker from the upper housing.
Remove four 9mm Phillips #0 head screws from the inside of the speaker case.
Remove all cable connectors from the speaker motherboard.
Remove two 9mm Phillips head #0 screws from the battery holder.
Remove four 9mm Phillips #0 head screws holding the battery pack in place.
Disconnect the battery cable from the motherboard.
Lift the battery pack from the board.
What is the battery spec? Do you know if there is a larger/more durable one to replace it with?
crwdns2917034:0crwdne2917034:0
TJmart.pk is one of the main Online Wholesale and Retail Shopping
Websites in Pakistan. our Company provides the latest and good quality of '''Bluetooth devices in Pakistan'''.
7 Days Money Back Guarantee. Authentic &
Reliable Products with High-Quality Standards Guaranteed. Fast
Deliveries All Over Pakistan.
No Fake Listing, No Hidden Charges Cash on Delivery
