This guide requires basic disassembly skills to get inside the phone. Allowing you to pull out and then realign the buttons.
Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
Remove 4 13.8mm screws holding the device back using a Phillips #1 screw driver.
Removed 1 4.8mm phillips head screw with a #0 Phillips head screw driver and lift away battery back being conscientious of wires.
Carefully remove the button board to gain access to the buttons.
Carefully remove each button from the baby phone.
When handling buttons be sure not to misplace the button contacts.
