Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise
  1. Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, Remove base plug: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, Remove base plug: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • As other sonicare repair guides show, the base plug is only held in by friction. If you squeeze the sides it will open a gap you can slip a screwdriver in and lever out the base. A bit of cardboard protects the sides from cosmetic damage.
    • Have a look to an alternative opening procedure.
  2. Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, release locking tabs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, release locking tabs: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 2 tabs that prevent the insides sliding out. Release these with a small screwdriver while pushing the metal shaft at the other end, and when both tabs are free the innards will slide out.
  3. Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, Tighten loose screw: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, Tighten loose screw: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Phillips Sonicare 4300 (HX680C) - Fix Unpleasant Noise, Tighten loose screw: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screw circled was loose. Tightening this fixed the unpleasant noise. I had to use threadlocker to stop it coming loose again.
William Keogh
crwdns2935283:010/11/16crwdne2935283:0
187 crwdns2915208:0crwdne2915208:0
What is the size of that screw? Totally stripped mine
Screwstripper - crwdns2934203:0crwdne2934203:0
I believe I used a Phillips #1 on that screw. #0 seemed too small to me.
Caterwaul B. -
BTW, that Phillips #1 was on my HX686P (purchased as one of a pair at Costco in the US, which seems to be the same as an HX6829 when I try to look it up on Philips' website in their troubleshooter).
Caterwaul B. - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 105
crwdns2936753:030crwdne2936753:0 362
crwdns2942667:0crwdne2942667:0 2,649
