Philips TAS7505 Outer Shell Disassembly
  1. Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly, Philips TAS7505 Outer Shell Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 Outer Shell Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 Outer Shell Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Outer Shell Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips TAS7505 Outer Shell Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 Outer Shell Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
Joseph Hernandez
crwdns2935283:009/26/22crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 5-2, Adachi Fall 2022 crwdns2935289:0CSU Los Angeles, Team 5-2, Adachi Fall 2022crwdne2935289:0
CSULA-ADACHI-F22S5G2
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 892
