Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Liam Casto
crwdns2935283:004/01/24crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-4, Harley Spring 2024 crwdns2935289:0IUPUI, Team 1-4, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S1G4
crwdns2942667:0crwdne2942667:0 322
