Philips Sonicare ProtectiveClean 6500 Motor Replacement
  1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the bottom cap away from the toothbrush body.
    • If it is not easy to open, these alternative instructions may help you.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool to gently pry the ribbon cable away from metal motor chassis.
  5. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the twisted copper wires feeding from the top of the motor to the upper corner of motherboard.
    • Desolder the contact points.
    • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
  6. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the two connections.
  7. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the assembly over and remove the Phillips screw.
  8. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the motherboard and motor gently away from the motor chassis.
  9. Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare ProtectiveClean 6500 Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pointed tool to push in the tabs on either side of the white assembly .
    • Pull the wire carrier off of motor chassis.
    • Swap it to the new motor chassis.
Liam Casto
crwdns2935283:004/01/24crwdne2935283:0
354 crwdns2915208:0crwdne2915208:0
IUPUI, Team 1-4, Harley Spring 2024 crwdns2935289:0IUPUI, Team 1-4, Harley Spring 2024crwdne2935289:0
IUPUI-HARLEY-S24S1G4
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 400
